The air condition fan works only on occasion, usually when I start the car in the am, then after shopping and starting again, it will not come back on.
The A/C itself is working and air blows in from the outside as a result of moving, but no cold air if I am stopped.
It also will not adjust speed, it is either high or none at all.
The outside temperature display reads 50 even if it is 100 degrees outside.
Jul 23, 2010 at 6:54 AM
