2000 Oldsmobile Bravada
CHUCK44
  • 2000 OLDSMOBILE BRAVADA
  • 6 CYL
  • 4WD
  • 130,000 MILES
I hAVE A 2000 OLDS BRAVADA I CANNOT SHIFT IT OUT OF PARK. I HAVE LEARNED THAT IT IS THE SHIFTLOCK SOLONOID, BUT I DON!T KNOW WHERE IT IS LOCATED. COULD YOU KIND GENTELMEN HELP ME OUT?
Thursday, October 2nd, 2008 AT 1:22 AM
2CARPRO JACK
  • 11,533 POSTS
First check the fuses (back-up lamp, BTSI fuse)If ok remove plastic shield under driver side of the dash, locate brake light switch on pedal assembly. Test dark green/white wire for power with pedal depressed, if ok then you will need to remove the center console to gain access to the shift lock solenoid. Once you can get to solenoid on shifter, test same wire for power with brake pedal depressed, and test light green/black for power, if both ok, then the solenoid is bad
Thursday, October 2nd, 2008 AT 7:46 AM
