HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Bravada
Warning Lights
ABS Light
2000 Oldsmobile Bravada
SONYA46
MEMBER
2000 OLDSMOBILE BRAVADA
6 CYL
AWD
AUTOMATIC
94,000 MILES
WHAT DOES IT MEAN WHEN YOUR ABS LIGHT COMES ON? HOW WOULD I KNOW IF I NEED BALL JOINTS?HOW WOULD I KNOW IF I NEED A CONVERTER
Wednesday, April 7th, 2010 AT 2:23 PM
MECHANIC
The ABS light indicates there is a problem in the system. It could be a bad sensor, connection.
To check ball joints, you need to lift the front tires from the ground and then check for up and down play.
A bad catylatic converter will cause power loss, poor performance.
SPONSORED LINKS
Friday, April 9th, 2010 AT 7:44 AM
Please
login
or
register
to post a reply.
Related ABS Light Content
Abs Problem My Speedometer Doesn't Work Sometimes And...
Abs Problem My Speedometer Doesn't Work Sometimes And The Abs Light Comes On And It Won't Shift Out Of 2nd Gear, I Am Stumped
Asked by
darrell504
2000
OLDSMOBILE BRAVADA
VIDEO
How to Get ABS Codes Video
Instructional repair video
1997 Oldsmobile Bravada Abs Light On, No Ac/heater...
Electrical Problem 1997 Oldsmobile Bravada 6 Cyl Four Wheel Drive Automatic My Aunt Has Asked Me To Look At Her 97 Olds. Barvada It...
Asked by
atruegntlmn
1 ANSWER
1997
OLDSMOBILE BRAVADA
Transmission Wont Shift Out Of First Gear....
Transmission Wont Shift Out Of First Gear. Speedometer Does Not Operate. Abs Light On. Found Three Plastic Sensors In Transfer Case....
Asked by
Anonymous
2002
OLDSMOBILE BRAVADA
The Check Engine Light On And The Transmission Shifts...
Last Year, My Husband Took My Suv On A Hunting Trip. He Drove Four Hours (all Highway Miles). He Exited The Highway (and Came To A Complete...
Asked by
2CP-Archives
1 ANSWER
1997
OLDSMOBILE BRAVADA
Air Suspension Warning Light
Where Is The Air Suspension Warning Light On This 2004 Olds Bravada. My Rear Air Shocks Have Failed, But I Have No Warning Light That I Can...
Asked by
ckaiser3
2004
OLDSMOBILE BRAVADA
VIEW MORE
SPONSORED LINKS
ABS Module Replacement Video
ABS and Traction Control Module Replacement
Coolant Leak Symptoms
Online car repair manuals
