1999 Oldsmobile Bravada
BLONDEMADUSSA
  • 1999 OLDSMOBILE BRAVADA
  • 6 CYL
  • AWD
  • 154,000 MILES
HOW DO I PUT IN AN IGNITION SWITCH
Friday, August 29th, 2008 AT 1:27 PM
MASTERTECHTIM
  • 4,750 POSTS
You need to remove the housing around the steering column, its held in with torx screws. And you will also need a special inverted torx bit to remove screws holding in the switch. Im pretty sure your parts store will carry the tools you will need but they might not have the real deep one you will need to remove the ignition switch screws. What I did on my first one was take the regular inverted torx socket to the grinder and ground it down enough to make it work. Good luck
Friday, August 29th, 2008 AT 1:42 PM
