Hi:
Certainly, it could be a ball joint, a tie rod, or any steering component. Also, if you have a brake issue, it can cause that as well. For example, if the left caliper isn't working properly, the majority of the braking will be done by the right side causing a pull. Do me a favor. I would first recommend lifting one wheel at a time in the front and checking for play in the wheel. Also, take a look through this link and let me know your thoughts.
https://www.2carpros.com/articles/car-pulls-right-or-left-when-driving-or-braking
joe
SPONSORED LINKS
Tuesday, December 17th, 2024 AT 7:06 PM
