2001 Oldsmobile Aurora
AURORA1
  • 2001 OLDSMOBILE AURORA
  • V8
  • FWD
  • 74,000 MILES
CAN THE STABLIZE SYSTEM MAKE MY CAR SHAKE
Tuesday, May 5th, 2009 AT 10:24 AM
ERNEST CLARK
  • 1,730 POSTS
You need to provide a little more information.
Does your car shake and wobble only when you apply the brakes? Does it get worse as speed increases?
Your stability control can not make your car shake and wobble. If it occurs ONLY when you apply the brakes, then it is your rotors are out-of-round, you have a caliper loose, ect. (It will be something related to your brakes)
If it occurs when the brakes are not applied, and gets worse as speed increases, then it's either a tire/rim out of balance, an axle/C.V. Joint bent, or another suspension related problem.
Tuesday, December 29th, 2009 AT 11:06 AM
