Oldsmobile Alero traction control
OLDSMOBILE ALERO
IRWIN HERSCHLLAG
Oldsmobile Alero 4 cyl Front Wheel Drive Automatic 70,000 miles
Can a stuck caliper cause the ABS traction control light to go on?
Mar 29, 2008 at 4:15 AM
SERVICE WRITER
  • 9,123 POSTS
The only way it would if it was stuck so that the wheel was skidding while you were driving.
Do you hear and humming noise while driving that changes pitch on slight right or left turns?
This is problem related to a speed sensor or speed sensor circuit.
Mar 29, 2008 at 5:16 AM
