2001 Oldsmobile Alero Theft System
TECH 1
  • 2001 OLDSMOBILE ALERO
  • 4 CYL
  • FWD
  • 95,000 MILES
While driving my car one day the theft light on the dash came on with no drivability concerns. After shutting off the car and restarting it the light was off. A couple of days later I tried to start the car after comming out of the store all it would do is crank over and not start. Noticed the theft light on the dash flashing while cranking. I tried to relearn the PATS system by turning the key to the run position and letting it set for 10 min. Still no start. After trying this twice with no fix I tried another key with the same procedure and it started and quit right after. One more time and it started and ran fine for another day. A day or so after that same thing happened with the "good key". Once again the relearn seemed to work. Symptom is intermitent. A theft detected code was retrieved from the BCM. Any thaughts would be great. Thanks
Saturday, June 7th, 2008 AT 9:18 AM
MASTERTECHTIM
  • 4,750 POSTS
Replace ignition cylinder, this is the most common cause. You need to get it from the dealer to have them code it to your key, remember the key does not have a code in it, its the ignition cylinder that has the code. I think parts will cost you around 150 to 200. Let us know how you make out
Saturday, June 7th, 2008 AT 9:20 AM
