1999 Oldsmobile Alero Wheres the coolant going
STANLEYWRIGHT
  • 1999 OLDSMOBILE ALERO
Engine Cooling problem
1999 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
I have a 99 alreo and the coolant just keeps dissapering it is not in the oil or the exaust havent found a leak anywhere but every time I turn off the car it sucks up all the water it has also been running hot.
Sunday, October 10th, 2010 AT 5:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If its not leaking visually (wet spots) than it has to be getting burnt through exhaust. Check inside car as well for wet spots, especially passenger side under dash.
Sunday, October 10th, 2010 AT 7:22 PM
STANLEYWRIGHT
Not in exaust or under the dash not in the oil and the heater isn't working I have visualy looked every where.
Monday, October 11th, 2010 AT 1:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check transmission fluid, the oil cooler could have internal leak letting coolant mix into it
Monday, October 11th, 2010 AT 8:49 PM
