1999 Oldsmobile Alero air conditioning fan
SHADELAND54
  • 1999 OLDSMOBILE ALERO
  • 4 CYL
  • 86,847 MILES
When I start the car and turn the fan on it works for about 30 seconds and then stops. Then the fan goes on and off after that. The air is cold so I think it's just the fan.
Wednesday, July 7th, 2010 AT 2:29 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation. Is it your engine fan or your blower fan turning on and off?Also what model alero do you have?
Wednesday, July 7th, 2010 AT 2:34 PM
SHADELAND54
It's a 4-door GX 2.4L. It's the blower fan.
Wednesday, July 7th, 2010 AT 2:42 PM
SATURNTECH9
  • 30,869 POSTS
I emailed you the blower motor location and the wire diagram. Lets start by putting the blower motor on high and wiggling the blower motor connector around and see if it's a loose connection. Then we can go from there do you have a multimeter?You will need one to do some testing.
Thursday, July 8th, 2010 AT 11:25 AM
