1995 Oldsmobile Achieva power steering hose
1995 OLDSMOBILE ACHIEVA
CARRIMARIE
Steering problem
1995 Oldsmobile Achieva 4 cyl Automatic 171000 miles
My car is leaking power steering fluid from either the pressure hose or the return hose...how can I figure out where it is leaking from?
Sep 29, 2010 at 12:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Start your vehicle's engine.
Have an assistant turn the steering wheel left and right, lock to lock, while you look underneath the vehicle. You will need to look under the front of the vehicle to see any leaks coming from the lower power steering hoses. Once you locate the leak in the power steering line, you can trace it back to the source of the leak. Sometimes, a leak will run down the hose before finally dripping onto the ground. Knowing where it is dripping, however, provides you a starting point so that you can find the leak
Sep 29, 2010 at 12:26 PM
