1990 Oldsmobile 98 radio removal
STUEBROWN
Interior problem
1990 Oldsmobile 98
HELP......
trying to remove radio from 1990 olds 98 regency
can't readily find chiltons for that year.....
don,t want to make more work for myself than necessary
Mar 28, 2010 at 1:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.disarm the Air Bag system. 2.Remove the center trim plate screws and pull off the trim plate. 3.Remove all attaching screws and remove the entire lower trim piece. 4.Remove the radio mounting screws. 5.Slide the radio out, disconnect the wiring and antenna cable, then remove. Transfer the mounting brackets if necessary.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528004a9ab_1.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_2_99.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_3_46.jpg
To install: 6.Position the radio, connect the antenna and wiring, and secure with the screws. 7.Install the lower trim piece. 8.Install the center trim plate. 9.arm the Air Bag system. 10.Check all functions of the radio for proper operation.
Mar 28, 2010 at 6:52 PM
