1988 Oldsmobile 98 brake lights
1988 OLDSMOBILE 98
300,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS1966
how do you take apart the tail light frame to change
the brake light bulb? also the reverse light frame?
Mar 5, 2010 at 7:09 AM
  • 110,244 POSTS
Open the trunk and remove the carpet near the rear tail light assembly. Under the carpet, you will see 3 or 4 whing nuts that hold the light in place. Remove them and the entire assembly will come out and then you will have access to the bulbs.
Apr 15, 2010 at 5:23 AM
