1997 Oldsmobile 88 skips going uphill
1997 OLDSMOBILE 88
79,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHERRYBARKER
bought 97 Olds 88 LS in good condition, and then noticed it skips going uphill sometimes, changed oil and filter, fuel filter, spark plugs, added STP and some higher octane gas but still skips sometimes, can you tell me what may be causing the problems???
Apr 12, 2010 at 7:29 AM
  • 110,240 POSTS
Has the check engine light come on?
Apr 14, 2010 at 5:17 AM
SHERRYBARKER
No, engine light has never come on, and no other problems, think it might be failing fuel pump?
Apr 14, 2010 at 9:35 AM
  • 110,240 POSTS
It could be. Here is a how to for checking it. You will need a gauge. Most parts stores will lend or rent one to you. Check it and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Apr 14, 2010 at 3:07 PM
