Is there another way to bleed the brakes without useing the bleeder screws
Apr 19, 2009 at 5:01 AM
BLACKOP555
✓Experienced Mechanic
no there is not! are you having problems loosing up the bleeder screws? try hitting on it with a steel hammer and around it to jar it free. then turn it clockwise to tighten then put ratchet in loosen and tap it with hammer till it moves. use a 6point socket.
if that dont work use heat.
Apr 20, 2009 at 11:40 AM
