1995 Oldsmobile 88 80000 miles
I need to know the bolt size on the brake light mounting. I tried an m6 as that seemed to match in the parts store but the fit is too loose. I had one miscellaneous bolt I found that fits perfectly. This is the bolt that screws into the brake assembly that mounts to the tail light bracket.
Apr 3, 2010 at 7:50 AM
