1992 Oldsmobile 88 Finding the leak
1992 OLDSMOBILE 88
94,000 MILES • V8 • FWD • AUTOMATIC
CRAMERROB
I have a 92 olds 88 and it's just dropping all of it's coolant. I'd like to keep the car, but I cannot find the leak. My radiator and hoses are all solid and in good shape, and replaced both the thermostat and water pump and the problem still persists. The leak appears to be comming from behind the motor mount closest to the w. pump. Where are all the possible locations for this leak, I'm at my wits end, please help.
Thank you soooo much, and safe and happy holidays to you and yours.
Dec 20, 2008 at 7:22 AM
LEGITIMATE007
  • 5,121 POSTS
it can come out of inside the timing chain cover, also from inside the water pump, heater hoses that go into the firewall and connects to the heater core, the heater core can be cracked and its leaking into the a/c condensation pan and then dripping out of the little nipple comming from the fire wall, also it can be comming out of one of the freeze plugs in the engine block
Dec 20, 2008 at 7:27 AM
