Will not turn over with ignition switch. Can jump across starter and will crank but will not stay running.
Saturday, October 16th, 2010 AT 11:49 AM
MECHANIC
Hi soney77, Welcome to 2carpros and TY for the donation
If you have to do that-You need to check and test the park and neutral switch and ignition switch. If its starting and stalls immediately this can be caused also by the ignition switch-if not check the fuel pressure if its within specs-
