1992 Oldsmobile 88
LISANODRAMA
  • 1992 OLDSMOBILE 88
  • 6 CYL
  • 4WD
  • 233,339 MILES
I was driving and my car just turned off and I'm not sure why.
Monday, March 22nd, 2010 AT 12:47 AM
Might want to do below if its cranking over and refuses to start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, March 22nd, 2010 AT 6:00 AM
Related General Content
