So far had the Crank Sensor and Cam Sensors replaced, had the Ignition Module replaced twice, starter is new as well. Now the Engine light comes on and throws off codes 34 and 44. Mass Air-flow sensor and Oxygen sensors? Will these two things be the problem? It only happens when the car is driven a short while, not from the beginning when cold? Any advice, Do we put more money into this? Thanks.
SPONSORED LINKS
Tuesday, March 9th, 2010 AT 10:01 AM
