Oil pumping out from oil filter
MAHMAQ12
  • 2012 NISSAN TIIDA
  • 36,000 MILES
While starting oil pumping out from oil filter. Like shower
Thursday, May 2nd, 2013 AT 12:34 PM
CARADIODOC
  • 34,364 POSTS
The common cause is the oil filter is "double-gasketed". The old o-ring gasket from the old oil filter sticks to the engine when the filter is removed. If no one sees it, the new gasket on the new filter goes over the top and you have two gaskets. There's a ridge on the filter to keep one gasket from squirting out but nothing to hold the old one. Oil pressure will blow the old gasket out and you'll have a major leak.
Thursday, May 2nd, 2013 AT 1:35 PM
Related Oil Pump Content
Oil Pump and Pan Replacement
VIDEO
