Oil light comes on when I am braking
65,000 MILES • 4WD
EWALKER80
I recently got my oil change and I notice this morning that my oil light was on. I got my oil change again and they said my oil filter was leaking. could this be the cause why my oil light is on?
Oct 31, 2019 at 9:11 AM
SCGRANTURISMO
  • 4,897 POSTS
Absolutely. There should absolutely no reason why your oil filter would be leaking. Often times what will cause this to happen is when whoever is doing an oil change they will forget the old oil filter gasket and it will stick to where the oil filter goes. Not realizing this, or not taking the time to check, which is more like it, they will install the new oil filter and tighten it but it will be double gasket, and leak. The only other way it will leak is if it got crushed somehow, or it didn't get hand tightened, either way, whoever did your oil change is responsible for correcting it, free of charge, and any damage that may have happened to your vehicle's engine. Please keep us informed as to the situation.
Thanks,
Alex
2CarPros
Oct 31, 2019 at 11:48 AM
EWALKER80
My oil light is still going on and off after the oil change. should I wait a couples days to see if it will go off?
Oct 31, 2019 at 1:42 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Does the light only come on at an idle or does it do it when at higher than idle RPM's? Do you see any leaks? Have you checked oil level? Also, what brand oil filter was used. I've seen the light come on with an inexpensive filter.
Let us know. The most important thing is to make sure there are no leaks and when the light is on, make sure there are no engine noises such as ticking or knocking.
Oct 31, 2019 at 1:46 PM
EWALKER80
My car runs good. I got my oil done at Walmart last week and today my oil lights came on. I took it to Menike and they said that my oil filter was leaking and they changed it but the light is still on.
Oct 31, 2019 at 1:54 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Can you check your engine oil level on the dipstick and make sure that it is okay? Please report back here with what you find out and we can go from there.
Thanks,
Alex
2CarPros
Nov 1, 2019 at 7:07 AM
