the oil light turns on then about a minute or two the engine stalls to about 5 miles per hour, even if i step on the gas. so ill park and shut off the car, a couple of minutes later ill start it and drive normally. then it repeats in about 5 to 10 minutes. ive changed oil and oil filter , transmission filter and fuel filter. but it continues to happen. i was told could be oil pressure sensor or fuel pump problems ?
Oct 21, 2015 at 7:13 AM
