I am replacing the compressor, accumulator, and orifice tube in my van. When I got the new compressor, it says it comes with 2 ounces of PAG oil in it. After looking it up on ProDemand, It says that the total oil capacity is 11 ounces. And If you replace the accumulator, to drain the oil out of it and add in 2 ounces plus however much you drained out. When I removed the accumulator, there was not a drop of oil that spilled out. Nor was there when I removed the compressor. The odd thing is, ProDemand says that the OE replacement Denso compressor comes with 8 ounces of oil in it.
So, how much oil do I add? It's very confusing, and I think the system might be entirely dry beside the UV dye I put in.
Sep 8, 2020 at 1:26 PM
