Oil bolt
120,000 MILES
MLEINSTEIN
Oil bolt won't come out. Just spins. Think threads in pan are stripped.
Jan 30, 2016 at 5:40 AM
  • 31,937 POSTS
You may be able to apply a little leverage behind the plug as you turn it and it may move, otherwise you may have to drill it out and re threaded the sump with an over size plug, regardless how you remove it it must be re threaded or if badly damaged replace the sump.
Jan 30, 2016 at 6:07 AM
MLEINSTEIN
We've tried putting something in between the plug in the pan and turning it. We tried by saying the plug and tapping it with a hammer we've tried re-tightening it we've tried all that and can't get it out.
Jan 30, 2016 at 6:12 AM
MLEINSTEIN
Vicing not saying
Jan 30, 2016 at 6:13 AM
  • 31,937 POSTS
Hold the plug with vice grips and start drilling with small drill go up sizes gradually until you can pull the plug out, don't worry about the thread as it will be damaged already, just remove the plug and then you can look at re threading or welding a plate over the damaged drain hole and drilling and re tapping a new drain plug.
Jan 30, 2016 at 6:22 AM
MLEINSTEIN
Ok. Then should we flush to get out metal shavings?
Jan 30, 2016 at 6:23 AM
  • 31,937 POSTS
Yes, and you can use grease on the drill to help capture metal as well.
Jan 30, 2016 at 6:26 AM
