oil and filter change
180,000 MILES • 4.2L • 6 CYL • FWD • AUTOMATIC
JOE1953
  • 812 POSTS
How many quart of oil does this engine hold when changing the oil and filter? I put 6 quart in the engine, but it looks like it needs more oil. I can't see the oil on the oil dipstick when I check it.
Mar 15, 2016 at 12:29 PM
JOHNNYT73
  • 924 POSTS
This engine requires 7 quarts of oil when changing the oil and the filter. Be sure to start then engine first after you put the new oil and filter on to fill the new filter. This will give you an accurate reading on your dipstick.
Mar 15, 2016 at 12:48 PM
JOE1953
  • 812 POSTS
I started the engine after I put the new oil and filter in, I adding 6 quarts, so are you saying I need to add another quart before I do any more driving?
Mar 15, 2016 at 1:08 PM
JOHNNYT73
  • 924 POSTS
You can still drive the vehicle without any problem. Just when you get the chance add the quart.
Mar 15, 2016 at 1:19 PM
JOE1953
  • 812 POSTS
I am not sure if this is a 4 cylinder or a 6 cylinder, does the 4 cylinder and 6 cylinder hold the same amount of oil when changing the oil and filter? I do know the engine is a 4.2L
Mar 15, 2016 at 1:39 PM
JOHNNYT73
  • 924 POSTS
There is no 4 cylinder option in the envoy/trailblazer. The 4.2L is an inline 6 cylinder engine.
Mar 15, 2016 at 1:47 PM
