What does this mean, tid$04 cid$09 high sensor voltage for switch time calculation?
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MARKOL69
What this mean:
tid$04 cid$09 high sensor voltage for switch time calculation.
Aug 13, 2023 at 3:56 AM
  • 55,709 POSTS
The message you've provided, "tid$04 cid$09 high sensor voltage for switch time calculation,"
In your case, "tid$04 cid$09" refers to a specific parameter or data identifier within the vehicle's diagnostic system. "High sensor voltage for switch time calculation"
We should do a CAN scan; you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Aug 14, 2023 at 6:47 AM
