OBD will not read. Has any run into this before? Checked fuses and they were good. OBD is getting power but will not read.
Nov 5, 2018 at 10:07 AM
✓Experienced Mechanic
Good morning.
When you hook up to it, does it give you a no communication message? If it does, then it could be either the serial data line to the PCM has a problem or the actual PCM is the failure.
You need to have someone check this for you.
Why are you checking the codes? Do you have a problem?
