Not sure if timing is not right?
2006 FORD ESCAPE
70,585 MILES • 2.3L • AWD • AUTOMATIC
CORKY88
  • 15 POSTS
I thought the timing chain was broken because the engine was turning over real easy, which still does. I check the timing chain and it was good. I put everything back together, but the engine still turns over fast, but when I let go of the key that's when I get the spark. So I am not sure if I have the timing right. Any idea why the engine is turning over so fast? It's like the timing chain is broken.
Mar 8, 2016 at 5:51 AM
HMAC300
  • 48,601 POSTS
try resetting your security system if no manual look online for your car
Mar 8, 2016 at 7:11 AM
CORKY88
  • 15 POSTS
Okay, I will try that, thanks!!!
Mar 8, 2016 at 8:03 AM
