not sure
2001 DODGE NEON
120,000 MILES
MATTR21
car beeps everytime i let off the brakes, is it serious?
Apr 28, 2013 at 1:08 AM
we have no info here. can you explain in detail????
beep??? from where???
Apr 28, 2013 at 6:33 AM
MATTR21
alright, i dident notice it at first until i got in a traffic jam, every time i let off the brake to go forward, it would beep once, sounds like the seat belt beep, but only one, instead of a series. not sure what else to tell you. gas was full, heat was fine, and no lights were on.
Apr 28, 2013 at 6:44 AM
make sure all doors are closed securely and buckle all seat belts to see if it is still there. Are you hearing a chime from the instrument cluster or a squeak from the brakes? If you're hearing a chime, check the gauges and warning lights, and check the brake fluid level. If the level is low, add just a little fresh, clean brake fluid. Do not fill the reservoir. Have the brakes inspected for wear.
If you're hearing a squeak when you release the brake pedal, that has an easy fix but it requires removing the rear brake drum.
Apr 28, 2013 at 6:51 AM
MATTR21
problem still persists.
Apr 28, 2013 at 6:58 AM
