Will not stay running like gas cutting off
2005 BUICK RENDEZVOUS
236,789 MILES
DAISY LOU 2020
Changed the fuel filter now it started but stalling out.
Apr 21, 2020 at 9:21 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you might be having an issue with fuel pressure. It's possible the fuel pump is weak/defective. If you don't have access to a fuel pressure tester most auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved:
The specification for your vehicle is 52-59 p.s.i. with the key on-engine off. Hope this helps and thanks for using 2CarPros.
Apr 21, 2020 at 10:07 AM
