Not running smoothly and frequently has a misfire
302,100 MILES • 1.5L • 4 CYL • FWD • MANUAL
CHAMILA JAYASUNDARA
I have b11 wagon car. Although it is not running smoothly frequently it has a miss in all the gears. I have done several repairs. But the it has got the same result. Following replacement and repair have done at the moment.
01. Carburetor repaired. It means clean all the parts and re fixed.
02. Replaced platinum point, ignition coil, resistor, condenser.
03. Cleaned fuel filter, but not replaced.
But it is not running always. Please give me advice to correct the problem.i would appreciate your immediate answer.
Oct 6, 2016 at 1:26 AM
  • 55,728 POSTS
Lets start by checking the compression in all cylinders, here is a guide to guide you started.
Please let us know what you find so it will help others.
Best, Ken
Oct 10, 2016 at 2:58 PM
