non start and ignition switch problem
79,000 MILES • 3.2L • 4 CYL • TURBO • RWD • MANUAL
KATTRELL
the boxster pre 2004 suffers with a problem ignition switch . The problem I have is the car will not start and the ignition key barrel is not sitting in its required position. I have been unable to lock the car remotely ,which I understand is due to the ignition switch. I jumped started the car recently as it had been left for 3-4 days and it started without no hesitation, went back the next day and the battery was completely flat only flashing some dash lights. I put a trickle feed on the car for 3 hours and still nothing. Is this a cause of the ignition switch staying live?. Your input would be very much appreciated
Apr 29, 2015 at 1:52 AM
  • 55,710 POSTS
It sounds like the battery is bad because it cant hold a charge, also the ignition switch should be replaced, there are several contacts which are internal that must operate correctly.
Do a draw check on the battery first,
Check this link
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know what you find
Best, Ken
May 3, 2015 at 3:02 AM
