noisy engine overheating and symptoms no longer apparent
236,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
H.MANIAPOTO
When I started my car my engine made a loud rattling sound. I tuned it off and the rattle became intermittent and the temperature gauge came on after a couple of miles while driving it to the repair garage.
The garage said engine was beyond economic repair so I took it home and parked it up for about a four to five months while I looked for a reconditioned engine for it.
However, when I went back and started it again the noise had stopped and the engine no longer overheats. I have run it for over thirty minutes without any of the symptoms recurring.
I checked the oil and yep, the tell-tale signs that were there when I parked it up were still present. yellow goo on oil filler cap and on the dipstick.
However, running the engine with the radiator cap off produces no visible bubbles although I did have to top-up the coolant reservoir which was low. After all the standing time the only thing that failed was the battery went flat, but was all good after I charged it up.
Can you explain why the engine problem is not occurring now, and what would cause it to disappear now? I am really puzzled.
Oct 15, 2017 at 10:27 AM
  • 31,937 POSTS
If you get the engine up to prolonged normal operating temperature you may well find the problem is back, the sure way to prove this is with a head check, this is a simple and quick chemical test for exhaust gasses in the cooling system, most mechanics can do this test while you wait. a positive test will be a head or gasket problem.
Oct 15, 2017 at 9:32 PM
H.MANIAPOTO
Thanks MHPAUTOS. will get that done as soon as possible.
Oct 16, 2017 at 9:36 AM
  • 55,746 POSTS
Here is the test in case you want to perform it yourself.
Please let us know what you find. I'm interested to see what it is.
Cheers, Ken
Oct 17, 2017 at 11:05 AM
