Noises coming from under dashboard
74,066 MILES
JMELO26
My 2007 cts makes noises under the dashboard when you put the car in on position and also while the car running; clicking noise,and gorgling sound coming from driver's side of the car's dashboard. If anyone can help me I would gladly appreciate it.
Thanks
May 22, 2013 at 3:18 PM
SINBAD271
  • 169 POSTS
Check you coolant level at the radiator , may be low, if it is conduct a coolant pressure test, there is a leak in the system . The gurggle sound may be coming from your heater core which uses coolant . This can be mostly heard at first start up, or after a long cool down period. Hope this will help.
May 22, 2013 at 10:51 PM
JMELO26
Thanks sinbad, my coolant bottle is full but I don't know how to check coolant level at radiator because I don't have a radiator cap. How do I perform a coolant pressure test?
Thanks
May 23, 2013 at 12:27 AM
SINBAD271
  • 169 POSTS
I believe your over flow bottle has the cap on it ,it may take a special adapter to connect the pressure test tool. You may want to take it to a repair facility and have a coolant diag done. Tell them your symptom your haveing it may cost one hour diag time. But it is very accurate and will save you the possibility of blowing a head gasket which lead to more money . A facility like pepboys can be very helpful . Or some place you feel comfortable with.
May 23, 2013 at 3:10 AM
SINBAD271
  • 169 POSTS
Have it check for an air pocket there is a port to allow coolant system to be bled at usually around hose housing on top of intake manifold. Your welcome.
May 23, 2013 at 3:14 AM
