Noise when accelerating after sitting 8 months then replacing the rack and pinion?
52,000 MILES • 2WD • AUTOMATIC
STAYLO27
My car was sitting at the dealership for 8 months waiting for them to get a rack and pinion. (Previously my car was making a clicking noise that was getting progressively louder and they replaced the steering column and then this trying to solve it. It’s been frustrating given the low mileage of a typically reliable car.)
I finally got my car back today and it was immediately making an unusual noise when accelerating. It’s hard to describe but it is louder than it should be and almost sounds like it’s struggling. If I accelerate really slowly, it doesn’t happen, but it can be heard if stepping a bit firmer on the gas.
I’m concerned there is an issue from my car sitting for so long. They reassured me they checked everything before giving it back to me, but I’d like some other feedback on if this is unusual noise (and not just me forgetting what my car sounds like), and maybe some possible causes for it before I reach out to them tomorrow and have to take it back in yet again.
Aug 14, 2023 at 4:07 PM
  • 55,746 POSTS
Thanks for the videos. This could be normal; I heard the engine laboring. Does it seem like the transmission is slipping? Do you have a check engine light on? It might be worth running the codes, this guide can help. They may have left something loose when doing the job like a cradle bolt or engine mount, I would definitely take it back and ask them to double check their work.
If it still makes the noise take it to an independent shop for a second opinion. Please let us know what happens.
Aug 15, 2023 at 4:22 AM
STAYLO27
It turns out they didn’t put the drum on fully when changing my rack and pinion. It was causing air to move through, and you could hear the engine a bit more than usual since it wasn’t sealed. The mechanic clipped the drum piece on and it fixed the noise!
Aug 21, 2023 at 5:08 AM
  • 55,746 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Aug 22, 2023 at 3:34 AM
