Noise and low RPM and low speeds
2011 SUZUKI ZEN
75,000 MILES • 3 CYL • 2WD • MANUAL
SURANJITH
I own a 2011 Maruti zen manual which has done 75,000 kms. I hear a grr... grr... grr sound from the front of the vehicle when trying to accelerate in second, third, fourth and fifth gears under very little throttle at low RPM. I hear this sound in second gear at 25 kmph, in third gear at 40 kmph, in fourth 60 kmph speed.
Nov 20, 2018 at 2:03 PM
  • 110,244 POSTS
First, this model is not offered in the US, so my technical information is limited. However, it sounds like you are describing a bad wheel bearing. When you hear the noise, try this. Turn the vehicle quickly from left to right and back. Note if there is a change in the sound. For obvious reasons, make sure you are in an area where there is no traffic. LOL
Let me know,
Nov 21, 2018 at 7:55 AM
