Noise after I make a turn
176,876 MILES • V8 • 4WD • AUTOMATIC
CRIME943
It all started when I was making a left turn and then a noise started and then it stays after a good while. starts back up again after being stopped at a red light. rack and pinon or power steering?
Feb 11, 2019 at 9:48 AM
  • 110,248 POSTS
There are a few things which can cause a noise. Can you describe the noise or upload an audio clip so I can hear it?
The things I would suggest checking are as follow. Keep in mind, I don't know what it sounds like, so I am going to mention different things.
Check power steering fluid
Check belt condition
Check for leaks under the vehicle
Check axle and CV joints.
Check hub bearings
Check brakes
Here are a couple links you may find helpful:
https://www.2carpros.com/articles/power-steering-problems
https://www.2carpros.com/articles/clicking-sound
Let me know what it sounds like or if any of this information helps.
Feb 11, 2019 at 10:05 AM
