Won't drive in any gear
250,000 MILES • V6 • 4WD • AUTOMATIC
TARA5763DIAZ
I was driving and the gas pedal just stopped working, I pulled over and put it in drive and it just revved. No motion. No motion in any gear. No prior problems with the transmission. I took it to a mechanic before I drove it and code 0014 came up. Doesn't sound like transmission. What could it be?
Mar 7, 2016 at 6:42 AM
HMAC300
  • 48,601 POSTS
Check fluid level if dark brown or black have it towed to a transmission shop.
Mar 7, 2016 at 7:58 AM
TARA5763DIAZ
I had them check it and they said it was the transmission, but several people told me it couldn't be the transmission if it had no prior problems and the mechanic that said it was the transmission. I didn't even know about a sensor on the transmission. There are other people who I asked about it said it was probably a sensor. What do you think it is? The transmission or the sensor?
Mar 7, 2016 at 8:07 AM
HMAC300
  • 48,601 POSTS
It's the transmission, a sensor would still let it move.
Mar 7, 2016 at 8:25 AM
TARA5763DIAZ
Okay, I had a new transmission put in and it's still doing the same thing?What else could it be?
Mar 14, 2016 at 1:15 PM
HMAC300
  • 48,601 POSTS
was torque converter changed ? was this done by a reliable shop or a used one installed and someone didn't install the converter correctly and broke the gears on the oil pump? what color was fluid of original transmission that was replaced? Is the current transmission full of fluid? Is the transfer case working correctly or stuck in neutral?
Mar 14, 2016 at 10:43 PM
TARA5763DIAZ
The torque converter was changed. Everything installed by a very good mechanic. It was a used one though. The fluid of other transmission was black and burnt. It was filled with new fluid and I'm thinking it could be the transfer case. But could it be something as simple as a fuse? It was actually a GM transmission.
Mar 15, 2016 at 2:27 AM
HMAC300
  • 48,601 POSTS
Not likely a fuse. If it was a fuse it would go into gear, but not shift correctly. Check for a transfer case problem or something along driveline.
Mar 15, 2016 at 5:04 AM
