Hi Guys. Parked my car last night. Everything fine. Went to start it today. -30 below zero but had the battery maintainer on all day and block heater plugged in. Went to start it. All the gauges light up in full brightness with the full ignition key on tones. When I turn the key. I can hear a click. No crank. I swapped all the relays that have to do with the ignition. Still one click. My guess is the click is coming from around the park neutral position switch. Does it sound logical that it may have been forced out of alignment? Due to the cold? The shifter did seem very stiff the other day. Any thoughts? Thanks.
Jan 31, 2019 at 10:29 AM
