Reverse was working fine one day then the next it no longer worked as in it was like I put it in neutral. All the other gears work fine no slipping. It showed no signs of anything being wrong and the transmission fluid level is where it should be. I have an automatic transmission. any ideas on what could be the cause?
Mar 24, 2019 at 8:03 AM
