No pressure in the clutch
142,136 MILES • 1.9L • 4 CYL • FWD • MANUAL
LOGAN ANDREW MOODY
I just replaced the master and slave cylinder, the third time in the past year. I also just replaced the entire clutch. Flywheel, throw out bearing, the whole nine.... Then I was driving down the road yesterday and all of a sudden. My clutch lost pressure again. It did so until I pulled into my driveway and turned it off. Then when I turned it on again. There was a little bit of pressure back. But I chose to try to bleed it again to make sure I wouldn't get stranded and now I have no pressure and it will not bleed. I have not a clue as to what to do from here. I'm not sure of anything else it could be. But I need help ASAP please if you have any ideas please help.
Aug 31, 2016 at 1:21 AM
LOGAN ANDREW MOODY
Also if you could respond to loganmoody13@icloud.com I would greatly appreciate it. I do not use the email linked to my Facebook.
Aug 31, 2016 at 1:22 AM
HMAC300
  • 48,601 POSTS
we only send replies from this site you can download this site to your computer. try gravity bleeding clutch first prior to using master or rent a power bleeder from a rent it shop and bleed that way
Aug 31, 2016 at 2:44 AM
