No Power to Radio after I changed the Battery
2009 BUICK ENCLAVE
87,500 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
RCBRIDGE
The car need to be jump started this morning. I drove it to work and two hours later checked and the car would not start. I went to Sears Automotive to check and replace as needed. They had to replace the battery and after the Radio/ system would not power up. All fuses have been checked and everything has power to it.
The screen does not come on period There is no sound of any kind. No beeping when the back hatch opens, no turn signal clicking etc, but everything works but the radio NAV system etc.
HELP
Jan 22, 2015 at 10:59 AM
TY ANDERSON
  • 719 POSTS
Did the radio work after jump starting in the morning? Did the radio stop working after Sears replaced the battery?
If I read that right is seems to me the issue is due to the battery replacement.
It sounds like a fuse is blown for the radio or the radio's amplifier. Has the climate where you live been rainy/wet or have you noticed water on the driver side floor mat area? These vehicle have been known to develop a leak from the sunroof drain on the driver side causing water to leak inside the vehicle onto the radio amplifier under the driver side dashboard area damaging the radio's amplifier
The beeping and turn signal sounds run through the radio to the door speakers.
Jan 22, 2015 at 1:07 PM
