No power to fuel pump
2006 TOYOTA VAN
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JUNIE320
i have the vehicle listed above, Isis. i'm not getting any power supply to the fuel pump during ignition nor cranking. i checked the fuel line to the engine and no fuel was coming up, so i checked the pump connection for power and didn't get any, but if i run 12v straight to the pump, the vehicle will run fine. checked fuses and relays, i have no burnt fuse. checked some websites online and my circuit opening relay is below the steering wheel, it's the blue 4 pin relay. i exchange the relay with the horn relay, and i still don't get anything at the pump, and the horn still works after the exchange. i tested where the EFI and horn relays are to try understand which side of the relay would get power during ignition and which side has constant power. after that, i tested by the circuit opening relay and realize i only have constant power. i'm not getting anything when the ignition is on. i hope i can get a feedback soon.
Apr 23, 2020 at 4:39 AM
  • 110,244 POSTS
First, I have to explain this vehicle isn't offered in the US. As a result, I have little to no technical information related. However, I'll try to help.
You mentioned there is no fuel or power to the fuel pump. Additionally, you mentioned the fuel pump relay. That could certainly be the cause if it is nonfunctional. I have no info as far as location, but here is a link explaining how to test one once you find it:
Let me know if that helps and what you find.
Apr 23, 2020 at 9:37 AM
