When accelerating, there is absolutely no power at all. Also, when idling and driving, it is missing on cylinders 1-3. I've changed all 6 spark plugs and ignition coils. It almost seems as if the timing is off. I've heard that these cars are known for bad sensors. Should I go ahead and change the camshaft and crankshaft sensors? if not, what else could it be causing the problem?
Oct 14, 2013 at 9:18 AM
