No odometer and no gear indicator will light up
100,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
DARRELL ALLEN TANSY
The gear indicator and odometer wont light up.
Nov 22, 2016 at 3:36 AM
DARRELL ALLEN TANSY
The ICP needs rebuilt the ckt board is fried the gear indicator and the odometer are LED and the board is burnt out . The Dealer rebuilds the ICP and needs the number off the back to see if they have that ICP in stock and will need the core and the problem is solved. cost of the rebuild is around $325.00 to $350.00 less the labor to remove and replace.
Nov 22, 2016 at 6:33 AM
  • 55,770 POSTS
Hey Darrell,
Great information. thanks for your input. Do you have any other questions?
Best, Ken
Nov 22, 2016 at 6:41 AM
