to keep it running I have to hold down the gas
183,645 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NICK BOX
  • 8 POSTS
I have to hold gas to get to crank then hold gas to keep running when pressure is off it cuts off. new Alternator new TPS and battery. Still will not ideal.
Dec 3, 2016 at 10:46 AM
CARADIODOC
  • 34,414 POSTS
You have already answered my first question, thank you. Was the battery disconnected?
You also described perfectly two of the three typical symptoms. You missed the loss of the nice "idle flare-up" to 1500 rpm's at start-up.
The Engine Computer lost its memory when the battery was disconnected. It has to relearn "minimum throttle" before it will know when it must be in control of idle speed. To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
Dec 3, 2016 at 12:02 PM
NICK BOX
  • 8 POSTS
Okay, but the battery was changed out two weeks ago but a load tester on it come back with 12.4 volts..
Also been looking for lose vacuum lines an have checked the one's on the intake an on the air intake to the valve cover all of the lines are intact with no leaks .
Any other idea's on this problem would be helpful?
Thanks,
Nick
Dec 3, 2016 at 9:41 PM
NICK BOX
  • 8 POSTS
Next question is would the IAC be causing this problem by some chance ???
Dec 3, 2016 at 10:07 PM
  • 31,937 POSTS
IAC can be an issue if the drive and re learn wont help.
Dec 4, 2016 at 11:45 AM
CARADIODOC
  • 34,414 POSTS
You missed my first reply. This has nothing to do with the battery being good or bad. It has everything to do with it being disconnected. Did you do the relearn procedure?
If you did the procedure multiple times and still have low idle speed, the easiest way to start the diagnosis is to use a scanner to view live data and look at what "step" is listed for the AIS motor. The Engine Computer will set it to one of 256 steps. As it positions the motor, it slowly rotates a threaded shaft, and doing that retracts or extends a pintle valve to expose more or less of a controlled air leak around the throttle valve. For a properly-running engine, step 32 is typical. With a single-cylinder misfire, you'll find it closer to step 50.
If you find the AIS motor is at step "0', and idle speed is too low, minimum throttle hasn't been relearned yet. Right now the computer isn't aware it is supposed to be in control of idle speed. Try doing the procedure while holding the brake pedal up with your toes. If that works, suspect the brake light switch is out-of-adjustment or it's bouncing excessively over bumps in the road. If it's at step "0" and idle speed is too high, the Engine Computer is trying to bring the speed down but without success. This is almost always due to a vacuum leak.
If you find a really high number but still have low idle speed, minimum throttle has been learned properly. The computer is trying to raise engine speed, but without success. That is the time to look at the AIS motor. A wiring problem too it would be detected, and you'd have read a diagnostic fault code related to that. When there is no fault code, suspect a sticking AIS motor or an air passage plugged with carbon.
Your AIS motor is different but similar to that used on Chryslers and GMs. As such, if you remove it, you should be able to push the valve in to retract it. You'll need to squeeze pretty hard, but it will move. Reinstall it that way. If idle speed is still too low, the air passage has to be blocked, or the Engine Computer is fully extending the valve as its first step in finding the starting point when you turn on the ignition switch. To prevent that, leave the AIS motor unplugged after you install it with the valve retracted. That will set a fault code, but you'll know if higher idle speed can be attained.
Dec 5, 2016 at 11:09 AM
NICK BOX
  • 8 POSTS
Thanks for the relearn option but did not work , but changed the IAC did a relearn process drove 28 miles interstate driving returned to shop with perfect 850 idle ...
Dec 5, 2016 at 11:31 AM
CARADIODOC
  • 34,414 POSTS
Dandy. A failure of the motor itself is by far the least common cause of low idle, but it can happen. If that happened to me, I would assume I overlooked a stretched connector terminal, or one that was corroded. I would second-guess myself, even after the problem was solved.
For future reference, you don't have to do the relearn procedure when you replace this motor, or any other part. On most brands of cars that use this type of idle speed control system, the Engine Computer is not interested in the step number it has placed the motor at. It is simply concerned with whether it needs to move the motor to a higher step, a lower step, or leave it alone. Being able to read the step number on a scanner is more a benefit for the mechanic. On most of these systems, the computer pulses the motor with its varying voltages and polarities to fully extend the valve as far as possible each time you stop the engine, then it immediately retracts it a specific number of steps so it's ready for the next engine start. At that point, at start-up, idle speed will immediately go to 1500 rpm, then drop to normal after a few seconds.
Also, since I'm sharing this wondrous information, what the Engine Computer is looking for during the relearn process is the signal voltage from the throttle position sensor when your foot is off the accelerator pedal. There is no way it can know when that is when the vehicle is idling at a standstill. Instead, it knows the throttle is fully-closed when the signal voltage is holding perfectly steady and intake manifold vacuum is very high. You can get that high vacuum from snapping the throttle and quickly releasing it, but that will not last for more than two or three seconds. When you coast down from highway speed, that high vacuum can last for WAY longer than seven seconds. The computer knows that can only occur when the vehicle is moving. At the same time it sees the throttle voltage is not bouncing around from your foot vibrating on the accelerator pedal, so it knows the throttle is at its lowest setting. That is when it takes the throttle position sensor's reading. From then on, any time it sees that same TPS voltage, it knows it has to be in control of idle speed.
It can be possible to run into an idle speed problem when you replace the throttle position sensor. They have ground, (0.2 volts) on one terminal, and 5.0 volts on the another one. The movable signal terminal picks a voltage off between those two extremes, but there are mechanical stops that limit that range of voltage. Those limits will vary between any two sensors by as much as a couple of tenths of a volt, but for circuit description purposes, the range is from 0.5 volt to 4.5 volts. (Readings outside that range are what triggers the computer to set a diagnostic fault code).
For my sad story, suppose you do the relearn procedure, and the TPS voltage at idle is 0.62 volts. From then on, any time the computer sees 0.62 volts, it will adjust idle speed. If you replace the TPS with one that develops 0.68 volts at idle, the computer will still be waiting to see 0.62 volts, so it will leave engine speed up to you. Most of the time the mechanic who changed the part does a test-drive including the relearn. When the car owner does this, most commonly they inadvertently do the relearn procedure without even knowing it is taking place.
You also have a 50 percent chance the new TPS will have a lower signal voltage at idle. The Engine Computer sees that, and knows that can't be a one-time thing. It immediately puts that new voltage in memory, and from then on, that is what it needs to see to know when to be in control of idle speed. It's only when the voltage from the new TPS at idle is higher that a relearn is necessary.
The need for this procedure can lead to frustration, but once you're aware of it, doing that is much easier than for cars with some of the earliest computer systems. Some of those required adjusting a new throttle position sensor to develop the specified signal voltage at idle. As far as the computer was concerned, there was just one correct voltage. Those cars didn't talk to scanners either, so we had to dig out a digital voltmeter, figure out where to connect it, find the service manual to see what to adjust the sensor to, loosen it to adjust it, . . . . It's far easier to just drive and coast.
Happy to hear you have this solved.
Dec 5, 2016 at 1:07 PM
