No fuel supply
2003 VOLKSWAGEN POLO
250,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
TLMNISI4
I just did engine overhaul after oil pump failure. everything was put together but when I start the vehicle the fuel pump does not supply fuel at all, but the fuel level is showing on the cluster. but the engine do give spark.
Jan 30, 2019 at 2:15 PM
  • 110,241 POSTS
Hi and thanks for using 2carpros.com
First, I have to say this vehicle isn't offered in the US, so I don't have specific technical information related to it. However, I am going to try to help.
First, have you checked the basics such as fuses and the fuel pump relay? Since the engine was out, recheck grounds which may have been disconnected or damaged also.
Here are a few links that may be helpful:
If the fuel pump wasn't a problem prior to the engine repair, it most likely a ground issue. Check for those issues and let me know what you find,
Feb 1, 2019 at 5:12 AM
