No Fault on diagnostic but check engine light on
16,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
KELLIEMCK
Light on, losing power but no fault on diagnostic test?
Sep 11, 2020 at 8:39 PM
Good afternoon,
Usually, when the check engine light is on, there is a fault code stored.
It may be your code reader that is not picking it up if it is in a system your reader cannot access. Take it to a parts store and have them read it for you with there scan tool.
Beyond that, it could be an issue with the ECM itself. As far as the low power, how long has it been since you changed your filters?
https://www.2carpros.com/articles/engine-has-low-power-output
Sep 12, 2020 at 5:51 AM
KELLIEMCK
It was super cheap auto that did the diagnostic test. it is due for a service so I’ll will change filters and get back to you once done. Hope it helps
Thanks for your time.
Sep 12, 2020 at 3:08 PM
You are welcome.
Keep us updated.
Always glad to help.
Sep 12, 2020 at 9:26 PM
