No D1, D2, D3. Do have reverse and park
95,000 MILES • 2.2L • 4WD • AUTOMATIC
BARBPC
Just driving down the street, turned a corner, and lost acceleration. Car coasted to stop but then unable to move forward in drive. Gear shift moves into drive position but will not go forward. I have been advised could be linkage. Does this sound correct?
Oct 25, 2019 at 12:37 AM
BARBPC
Just driving down the street, turned a corner, and lost acceleration. Car coasted to stop but then unable to move forward in drive. Gear shift moves into drive position but will not go forward. I was advised may be linkage broke. Does this sound correct?
Oct 25, 2019 at 1:25 AM
Good afternoon,
It could be but do you have park position?
Will the car back up in reverse?
Oct 25, 2019 at 2:03 AM
BARBPC
Roy, the mechanic could not bring up any codes. The transmission fluid level was good and no leaks. No sounds or warnings prior to the incident. The mechanic? just put it on a hoist to check for leaks and in minutes told me no codes so indicates a severe internal problem which means the transmission needs to be replaced. I have been told otherwise by others. I was advised could be bushings and linkage problems more probable. The car goes into reverse and park. Just no drive forward.
Oct 25, 2019 at 2:41 AM
Okay, based on your information, I agree with the mechanic. You have internal issues in the transmission and needs to be either replaced with a rebuilt unit or used unit.
Oct 25, 2019 at 6:31 AM
